Under Floor Heat Question
Old 03-17-05, 05:29 PM
D
There is a poster in the vinyl and linoleum forum that has discolored vinyl flooring over the underfloor heat pipes. Does this indicate any problem with the heating system?
Old 03-17-05, 07:31 PM
KField's Avatar
It could indicate a temperature of water/floor that is too high. The maximum water temp in the radiant system should be 140 degrees and the maximum floor temp should be 85. I don't think those temperatures would damage the flooring but higher temps could.
Ken
