70A-T 1/2" TEMPERING VALVE 120-160F
Old 04-01-05, 12:31 PM
magwa999
Would this have anything to do with having very little hot water? After about one minute the hot goes to lukewarm and then may heat up a little in five minutes. You never need to mix any cold water. Thanks
Old 04-01-05, 04:51 PM
Grady's Avatar
Tempering valve
Yes it certainly could be the culprit. The element can & does go bad. It sounds like yours may be stuck where it feeds too much cold.
Old 04-03-05, 04:14 AM
magwa999
Can you replace the insides?
Old 04-03-05, 08:20 AM
Grady's Avatar
Tempering valve
The insides of the valve can be replaced at about half the cost of a new valve.
Old 04-12-05, 04:13 AM
magwa999
Grady, I want to thank you for your help. I found the valve at Home Depot and just replaced the insides and that was all it took. It was only $27 and well worth it. You saved me a call to the plumber(not that I minded) and a few bucks, again thanks a lot.
Old 03-06-13, 05:43 AM
watts 70AF
Does the brass part need to be changed . it seems that i can easily replace just the insides. but when buying it i can only find it with the brass for about $40.
Old 03-06-13, 11:50 AM
Grady's Avatar
By "the brass part" I presume you mean the valve body which attaches to the pipes. If that is correct, no, you do not normally have to replace the entire assembly, just the inside.
