Upside-down pumps?
Old 04-27-05, 03:32 AM
brucecomo
Upside-down pumps?
Hello All...
My girlfriend's home has hot water heat/water that seem to work just fine. She's been told by a couple of different people that her pumps were installed upside down. Here are my observations; I'd be grateful for any education someone is willing to impart.
- The pumps labels are upside down
- The pumps never run
- When I first start a zone, the bottom pipe of the corresponding pump gets hotter than the top.
One aspect that really throws me is this: The cold return and the hot line appear to be connected.
There is a 6' stretch of pipe. On the left side, all 4 pumps connect to this pipe. On the right side, all four inlets(?) connect to the pipe. Both lines from the furnace connect in the center of the pipe. Shouldn't the pipe be separated?
The pictures can be found at http://mysite.verizon.net/vze6k4df/u...wnvalvespumps/
Thanks for your time...
Bruce
Old 04-27-05, 04:03 AM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
Can you draw it out and post back in this same post.
how????
ED
Old 04-27-05, 04:23 AM
brucecomo
Here goes my drawing...
P P P P | | | |
-------------------------------------------- <-- single pipe
furnace
Last edited by brucecomo; 04-27-05 at 04:23 AM. Reason: didn't like the way the drawing was rendered
Old 04-28-05, 11:29 AM
KField's Avatar
Your diagram isn't completely clear but it looks like it may be a primary/secondary loop setup. If it is, they usually work very well with respect to comfort. The pumps circulate water through the zone that is calling and the boiler adds as much hot water as it can to the loop. There are pitfalls but I would need to see a photo of the system or a pipe diagram to see them. I doubt that the pumps never run. They may be very quiet but if no water flowed, the house would be cold.
Ken
Old 04-29-05, 12:39 AM
brucecomo
Thanks for your reply and attempt at my picture. I will try to take a picture and post it somewhere where everyone can see it.
Thanks again,
Bruce
Old 05-02-05, 11:51 AM
brucecomo
Hello again...
I have a Quicktime video file (1.4 Meg) that shows the system I'm referring to. Is there a way to upload it to this forum?
Thanks,
Bruce
Old 05-03-05, 08:40 AM
Jay11J's Avatar
This web sight don't allow pictures to be posted.
You'll have to find another server that will host it and post it there.. Link us to that websight.
