Low hot water pressure
Old 05-23-05, 01:16 PM
cruizer9
Lately, I've noticed that there is not enough hot water pressure in my house. For example, if one shower is running and you turn on the hot water in the second bathroom it just drips. The hot water tank is in the garage. Is there anything I should check or is this a sign that my hot water tank needs to be replaced? Any suggestions appreciated. Thanks.
Old 05-23-05, 05:30 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Low H/W pressure
If this is a water heater, as opposed to a boiler with a domestic coil, I would guess at a bad valve or some other restriction in the piping. If it is a boiler with a domestic coil, you have to add the possibility of a partially plugged coil.
