Radiator joining ????
Old 07-21-05, 05:59 PM
Martin2
Question Radiator joining ????
I desperately need your help.
I have Four 2 feet cast iron radiators and I am thinking about joining them together so I can have Two 4 feet…….I have (Hot water system)
Any ideas?????
I had 2 four feet before and some one stole it from my porch while I was doing my floor, so I am thinking if this is possible since I have 4 of the shorter ones.
All connections are already there…I just need the radiators.
I could save some bucks.
Thank You
Martin
Old 07-21-05, 07:43 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Joining Radiators
I don't see what harm could come of it & they should work just fine. One thing to keep in mind is different radiator styles yield different amounts of heat.
With the nipples & union between the rads, you are going to be longer than 4 feet. The existing pipes will probably not line up.
