Location of auto. air vent in hot water\baseborad system?
Old 08-19-05, 04:21 AM
aberzins
Hi Folks,
I have a 3 zone hot water\baseboard heating system in my rancher. I have had problems with air in the baseboard heaters.
I would like to install some auto air vents to help eliminate these air problems - as currently there are none.
Therefore, where should they be located? Do I need to install one for each zone? At the start or end of the zone loop?
Or can I just install one auto air vent on the boiler? I was told that I could just install just just prior to the pressure relief valve? (tee off the line between the boiler and the pressure relief valve and then install the air vent here) I guess the logic is that it would remove the air from the boiler tank?
Thanks in advance for your help!
Aivars Berzins
Old 08-19-05, 05:29 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Auto vent(s)
If you can host some pix of the boiler & near boiler piping it would be a great help.
