baseboard hot water heater covers
I am painting the interior of an old house, and the baseboard heater covers are in bad shape -- dented, badly painted, ill-fitting -- so I would like to replace them. Can I replace just the covers without getting into the actual plumbing system? Or is it inevitably all one piece? This is gas-powered forced hot water system. The units themselves seem intact and the covers seem to come off.
Received 39 Upvotes
Baseboard covers
Depending on age & brand, the front panel will usually come off without much trouble but the top is usually part of back panel. I suggest removing the parts which will come off easily, sanding & painting with a good paint, such as Rustoleum or Krylon, made for metal. For the parts which can't be removed, sand & paint in place.
If they are badly dented and beyond repair you should be able to repace them, if you can carefully remove all the fronts, end caps and backings without damaging the fins too bad. You should be able to do this without much concern for the fin tubing.
Just measure the fin size height and depth and distance from the floor. Then when purchasing "enclosure only" you can check those measurements to make sure it will fit ok. MOST residential baseboard is interchangeable.
If you do bend some fins just re-straighten them as best as you can or you loose the heat transfer.
FYI...
I personally have never, nor ever seen anyone else install baseboard heating with nails. If you do, you are doing a hack job, just like they did in the days of the electric baseboard that I have replaces so many miles of, and that would just fall off the walls if touched. It was quite easy to remove that junk, but don't ever try that with my installations. Use a screw gun.
Help needed to find a part!!
HELPPP!!
I inadvertently threw away several of the "dampers" for my hot water baseboards. I am looking to replace these, since putting one of those covers over everything is tooooo expensive!!
http://www.slantfin.ca/documents/211.pdf
Debsters1 - Most baseboard is brand specific, so just replacing dampers without knowing the exact brand may prove quite difficult.
Who - Slant fin recommends either nails or screws, but being an installer of many feet of baseboard, I have found, In My Opinion that baseboard that is nailed on will over time pull away from the wall. especially if there are children in the home.
