fan for one zone keeps running
Old 10-10-05, 04:32 PM
tonynick1
i have a hydro air system with 4 zones the temperature on the boiler low 150 high 180 the air handlers are set to 140 .question ..the only way i can not have the 4th zone air handler not run is to put the air handler at 160 or higher any lower and the fan continues to run. is the circular pump running? how can i correct this problem. thanks
Old 10-10-05, 05:10 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Circulator running?
That is something you have to tell me. Are the pipes to & from the air handler hot? If they are, chances are the circ is running. Do you have a separate circulator for each zone or a single circulator with zone valves for each zone?
