remove baseboard
Old 10-12-05, 09:27 AM
telman
remove baseboard
I am removing a 6ft section of hot water baseboard in my kitchen.I have 3 zones,bsmt,1st and 2nd flr.I have access to this section in the bsmt ceiling.The boiler has a water inlet expansion tank and 3 zones controls with shut off vavles next to the control vavles.After shutting off the water and draining the water from my zone and removing the section of baseboard.What procedure do I follow to put back water in the system and bleed air from the system.
Old 10-13-05, 07:32 PM
I moved this thread so you can get an expert opinion in this field of expertise.
Old 10-14-05, 02:26 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Telman
This has been discussed a good bit of late. Please do a search of the threads. If you still need help, please post back.
