Hot Water Radiator Valve Leaking at Stem
Old 10-21-05, 06:51 PM
beanish
Hey all.
I have a slow but persistent leak at the stem of a 3/4" valve on a forced circulation hot water radiator. I've tried the lazy fix of finding a position in the turning radius where the leak stops, no luck.
I'm wondering if these valves have, what would be the equivalent of a "cartridge" in a faucet valve, or if i will have to replace the entire assembly (which i would like to try to avoid).
Any help would be much appreciated.
Cheers!
Old 10-21-05, 06:54 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Leaking valve
These valves can usually be re-packed. Go to your local plumbing supply house & get some valve packing. They can tell you how to do it.
Old 10-21-05, 06:58 PM
beanish
Thanks!
Grady,
Thanks a bunch for the information!
Now here's hoping I don't crack the thing with my channel locks tomorrow!
Thanks again!
Old 10-21-05, 07:13 PM
Grady's Avatar
Thumbs down Channel locks
Please use a wrench, even an adjustable is better than pliers. Good luck.
Old 10-21-05, 07:15 PM
majakdragon's Avatar
Received 1 Upvote on 1 Post
This may be a silly question but have you tried tighening the packing nut yet? Just a 1/4 turn at a time until the leak stops. Good luck.
Old 10-21-05, 07:25 PM
Grady's Avatar
Thanks Dragon
I sometimes make presumptions not in evidence.
Old 10-22-05, 08:59 AM
beanish
Thanks to both of you.
Dragon!
Not a silly question at all, as it turns out....
doh!
Problem solved!
Thanks again to you both
Old 10-22-05, 09:18 AM
Glad to be of assistance. Sometimes the simple things are overlooked. It's a shame though that you didn't get to learn how to pack a valve LOL.
