Main Zone Not Heating in new home
Old 10-22-05, 08:58 PM
BandAide
I just moved into an old house, over 150 years old. large house with 2 Hydronic multi zone systems. on the west furnace, the main zone, that includes the thermostat doesn't heat up. no water flow.
there are no zone controls in the system.
I thought that the old gate ( globe ) valves might be the problem, so I cut out the section of pipe in front of the valve, but still have no water flow.
I replaced it with a ball valve.
The other 3 zones work great, and I'm stumped, I'm thinking about cutting the zone into 2 parts to try to localize the blockage. this zone is the lower front bedroom and the upper kitchen heat run
Thanks, BandAide
Old 10-23-05, 10:17 AM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Zone problem
Does the circulator run? How is the boiler pressure? With the balance of the system working ok, I have to believe there is air in that part unless there is some kind of blockage (unseen valve?).
