Boiler and General Questions
Old 10-27-05, 09:03 AM
dixie77
I have recently mved into a new house with an electric boiler in floor pipiing in the beasement and radiators on the second and third floor. When I took possession, the circulator was not working properly and I repleced it with a new unit. Water is circulating fine and I have bled all air out of the system. Prolem is that the boiler never seems to get hot enough. The temp gauge will rise to 130 F and then the boiler will shut down. There are four elements inthe boiler and all LED's indicate that the elements are working correctly. The thermostat is a two wire type and is working properly. I'm wondering if this is a boiler problem (burned out elements) or perhaps the water is moving to fast to work as designed. There is a valve between the return and supply lines just above the boiler. Currently the valve is closed completely. Any thoughts?
Thanks in advance
Old 10-27-05, 06:26 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Electric Boiler
I hope you either have deep pockets or real cheap electric rates.
The best way to check to see if all of the elements are operating is with a clamp on amp meter. Check your control settings. They may be set at 130 for the floor loop.
