Mangled baseboard fins?
Old 10-31-05, 09:34 PM
dkpbxman's Avatar
Question Mangled baseboard fins?
After taking off the baseboard covers to paint them, I saw that some of the fins were pretty bent. While the pipes aren't leaking or anything, I was wondering if this is limiting the heat out-put?
It's a hot water system with an oil boiler.
Thanks,
Dan
Old 11-01-05, 06:10 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Baseboard fins
It does limit the heat output to some degree (sorry no pun intended). How much depends on how mashed the fins are. Often with patience & a pair of needle nose pliers, you can do a pretty good job of repairing them.
Old 11-01-05, 07:15 PM
dkpbxman's Avatar
Thanks
The previous owner must 've jammed them with the vacuum or something.
Old 11-03-05, 05:20 AM
T
I have some (also neglect from previous owner) that have much dust and dirt stuck between the fins. I wondered if that hurts heat output?? A vacuum will not pull it out and I am not sure how to clean it out.
Old 11-03-05, 06:39 PM
Grady's Avatar
Cleaning Baseboard
Built up dust & lint can & does hurt heat output. You can use any kind of fairly soft brush to "sweep" the contaminants out of the fins. A paint brush will work. Another, but far messier, way is to use a shop vac with the hose hooked up to blow.
