thermostats
Old 11-02-05, 03:48 PM
Unhappy thermostats
hi i put in a new thermostat but didn't look to see where the two wires were
screwed on to on the old one. i put red to the r and white to the w but i'm
not sure thats right. also the zone valves seem open all the time any help
thanks.should have paid more attention
Old 11-02-05, 04:11 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Thermostat wiring
Red normally goes to R or Rh & white to W. If you installed a digital thermostat, you should remove the jumper between Rh & Rc. If you have Taco or B & G zone valves, many digital thermostats are not compatible with them.
Old 11-03-05, 03:40 AM
thermostat
thanks i see where the mistake is now.out with the digi's
Old 11-03-05, 07:12 AM
zone valves
sorry to ask but i have taco valves and how do i know if they are open
or close the lever is in the up spot ?
Old 11-03-05, 04:20 PM
Grady's Avatar
Taco zone valves
If the lever is easy to move, the valve is open. If it takes some effort, the vavle is closed. No way to tell just by looking.
