Self-Maintenance assistance needed
Old 11-03-05, 11:34 AM
I have 2 questions:
1) When bleeding radiators, is it best to start with the lowest or highest radiators, or does it matter? Also, when is the best time - in fall as the heat comes back on, or in the spring after the heat shuts off for the summer?
2) What easy self-maintenance can/should I do for my expansion tank, if any? Do I need to drain once per year? If so, when (fall/spring)? I think I understand how to do it: turn off valve from tank to system, drain expansion tank, turn valve back on. Please let me know if this is necessary, and if so, why.
Thanks
Marc
Old 11-03-05, 05:43 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Marc
Let me preface my comments by saying this: Adding fresh water to a closed system is one of the worst things you can do to it.
If the radiators are heating ok, leave them alone.
Unless you have a pressure problem, leave the expansion tank alone.
Draining the expansion tank or bleeding the radiators introduces fresh water.
Old 11-04-05, 07:48 AM
There isn't any need to remove air from the system that slowly seeps in?
Old 11-04-05, 05:39 PM
Grady's Avatar
Removing air
If you are not having a problem, leave things alone.
