Radiator sounds like Water Bubbler!
Old 11-04-05, 05:53 AM
OutBackJack
Just bought a new place, so I'm new to the radiator scene. Anyways, last night I bled the radiator via the bleed valve. It hissed for awhile and then stopped, so I closed the valve. Now every once and awhile the radiator will make a bubbling sound much like a water bubbler! Can anyone provide some insight as to what's going on? Also, when you bleed air out of the system, should you leave the valve open until water drips out?
Old 11-04-05, 03:50 PM
nynextek
bleed
I'm not a pro...just a spectator but all of the pros say to bleed until water comes out.
Old 11-04-05, 04:37 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Water bubbler
Do indeed bleed the radiator(s) until you get a steady stream of water.
Old 11-05-05, 04:07 PM
OutBackJack
I've only gotten water out of one radiator. The others hiss for awhile and then stop, but no water....any advice?
Old 11-05-05, 04:23 PM
Grady's Avatar
No water
It sounds like the water feed valve is not feeding water or at least not feeding it as fast as it should.
