Weil McClain with loud rattle.
Old 11-05-05, 12:47 PM
inneedofhelp7
I have a very old Weil McClain boiler furnace that is making this extremely loud rattle noise when I turn it on. It was working fine 2 days ago, now it has the rattle.
I had it rebuilt 3 years ago. Does anyone know what the noise is, is it dangerous, and can I fix it myself? If it is a DIY project where can I find what parts it needs and instructions?
Thanks!
Old 11-05-05, 02:15 PM
U
Sounds like a bad flame. When was your last tune up? It should be tuned every year.New boilers and burners can go longer between tune-ups, but not yours. If your unit isn't firing properly it could soot up very fast. I think you should get someone out there asap.
Mike
Old 11-05-05, 04:37 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Rattling boiler?
I have never heard a boiler rattle. Sometimes if there is air in the system, a flow check will rattle. Draft reguators (barometric dampers) in the vent pipe can also rattle. This is usually due to poor combustion. Try to locate the source of the noise & post back in the same thread.
Old 11-07-05, 11:33 PM
inneedofhelp7
Hi thanks for the replies.
It sounds like the noise is coming from the circulator pump. Is it possible that the coupler is bad?
Or does this boiler have a vibration damper on it? I read online that this could also be causing it.
Are either of these a DIY project, and if so where do I buy the parts? If this is a overly expensive or too hard to do I will call a professional, but if there is a quick/cheaper solution I would rather try to do it myself.
Thanks again!
Old 11-08-05, 04:01 PM
Grady's Avatar
Rattle
Noises are tough to trace. The problem could be the circulator. Circulators are not that hard to replace. What kind of circulator is it? If it is a Bell & Gossett (B & G) with the springs which are in an "X" configuration, I suggest you replace that type of coupling with a Spiralink coiled spring type. The only tools you would need would be a 7/16" wrench & a 1/8" (maybe 5/32") allen wrench.
