Back boiler
Old 11-17-05, 10:31 AM
devil14772
Back boiler
The air lock that keeps my domestic and centeral heating water apart has burst. Do I need to empty the whole tank or just bleed the system through a radiator.
Old 11-17-05, 06:31 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Question Air Lock????????
I'm sorry, I don't know what you mean by "air lock". Do you mean the bladder in the expansion tank? Is the boiler going over pressure?
Old 11-30-05, 08:56 AM
jockademus
Just joined the forum and hopefully you can help with my back boiler problem. When the boiler goes off (temp reached) the boiler makes a lot of bubbling noises before settling down.
Is this something to do with pressure as you asked previuosly?
Old 11-30-05, 07:29 PM
Grady's Avatar
Bubbling noise
Bubbling (boiling) noises are common in dry base boilers & is caused by deposits in the waterways thus causing hot spots. Sometimes a chemical treatment will help, sometimes not.
Old 12-01-05, 12:15 AM
jockademus
So this is nothing to do with air in the system? The radiators also don't get as hot as they should?
Old 12-01-05, 06:11 PM
Grady's Avatar
Air?
Have you tried to bleed the radiators? Do you get water out of the bleeder on each radiator in a steady stream?
