No Heat!!!
Old 11-25-05, 06:32 AM
Frtsprt
No Heat!!!
We have a 15 yr old Trianco oil hot water baseboard furnace. Since we first tried to start using the heat this winter, we have not had any. We have hot water but no heat. The pressure is 0. My husband is being a butthead and won't ask for help but I'm freezing today.
Thanks!
Old 11-25-05, 07:47 AM
Grady's Avatar
Received 41 Upvotes on 39 Posts
No Pressure
No pressure means no heat. You need to get some pressure on the system. For a single story house 10-12 psi is fine.
Old 11-26-05, 07:22 AM
Frtsprt
how?
How do we get the pressure back? We have 4 different valves.
Thanks!
Old 11-26-05, 10:39 AM
H
Received 1 Upvote on 1 Post
makeup water line
you should have a makeup water line to the boiler that might be off or the pressure regulating valve is shot. This usually has a backflow preventor attached inline with it, and the data plate will usually say that on it, it will also have an overflow tube connected to it. Before you try add water to the boiler make sure you let rest for an hour first to cool off as much as possible to prevent thermal shock of cold water to a hot boiler....
