oil burner pauses help
Old 12-10-05, 08:43 PM
R
Ok I've a problem,
Slant/flin Liberty model L-30-K with Beckett AFG.
More than 1/2 tank of oil.
Last cleaning or service is over a year ago.
The burner pauses 3 or 4 times during it's cycle.
It does not turn off but stops for a brief moment several times when its running. I can hear it stop followed by the bang of the air vent in the chimeny.
What should I do?
Replace the fuel filter and or nozzle?
thanks
Rickc
Old 12-11-05, 05:08 AM
KField's Avatar
How many oil lines are connected to your fuel pump and where is the fuel tank? It sound slike air in the suction line.
Ken
Old 12-11-05, 08:13 AM
R
Ken
Ken,
It's a two line system with the tank in the ground.
Why was my Thread moved to Boilers-Steam & Hot Water Systems?
The Thread is about my oil heating furnace!
Rickc
Old 12-11-05, 01:51 PM
KField's Avatar
You may have developed a suction leak in the feed line to the burner. If it was mine, I would install a Tigerloop deaerator and cap and abandon the return line. If you decide to do this DO NOT take the bypass plug out of your pump if it is a Suntec or Beckett. It is also easier to use the flexible oil lines between the pump and the Tigerloop. They are expensive but simplify the piping. The air won't cause a problem to the burner with the tigerloop. You may also have a leaky fittin gon the suction side. If you have any compression fittings, start with them.
Your thread was moved because a Slant-Fin L30 is a boiler. Furnaces heat air, boilers heat water.
Ken
Last edited by KField; 12-11-05 at 05:05 PM. Reason: Gave bad info about bypass plug
