Bleeding oil fired boiler?
Old 12-18-05, 03:56 PM
C
Smile Bleeding oil fired boiler?
Hi,
I own a oil fired boiler,could you explain how to bleed the line in case I ever run out of oil?Thanks
Old 12-18-05, 06:14 PM
H
bleed the burner
if you look at the burner you will see something that looks like a car brake bleeder its usually a three eights fitting you will press the reset button to restart the burner open the bleeder when you get a good stream of fuel close and it should start
Old 12-20-05, 03:42 PM
Originally Posted by cschroth1
Hi,
From my own experience, starting the boiler and hitting the reset button 2 times should be enough to get it going or opening the inline filter and pouring in a cup of diesel to prime it always works.
Old 12-20-05, 05:11 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
mrbizness1
Your method may or may not work. Handyman18706 explained the right way to do it. If you have a two pipe system, you usually do not need to bleed the pump but on a one pipe you do.
