I want [Heating System] to be more efficient
Old 01-03-06, 12:37 AM
skipdow
tell me if this makes sense or will work......
currently I have an infloor gas fired heating system that also heats an indirect domestic hot water........currently its not as efficient as i'd like. The boiler is a condensing unit so i'm good there but i was considering installing a new mixing valve with an outdoor control AND a beckett heat manager into my system..... any thoughts? criticizems? ideas?
Old 01-03-06, 04:19 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Increased efficiency
Outdoor resets work quite well with radiant systems. In order to get the most out of the outdoor reset, constant circulation is the way to go. I don't know how well the Beckett Heat Manager would work with outdoor reset. My gut feeling is: Not very well.
Old 01-03-06, 06:42 PM
skipdow
the problem i have with constant circulation.(i assume that means through the whole house) is that I have 7 zones plus the domestic hot water..... how do you control temp in each zone?
btw ... does'nt the heat manager just control when the boiler comes on... just making it wait until the heat energy in boiler is used before it turns on depending on heat load?
Old 01-04-06, 05:46 PM
Grady's Avatar
Constant circulation
With constant circulation & outdoor reset, in theory, the boiler would only maintain enough heat to keep the thermostats satisfied. The big bugaboo comes with set back thermostats & system design/installation vs. the calculated requirements. The heat manager is supposed to create longer, less frequent burner runs by, as you said, holding off the burner until the usable heat in the boiler is used up.
