Popping noise from boiler
Recently had a repairman replace my pump. Since the repair, I've had popping and snapping noises coming from the boiler. The repairman used my water heater for added pressure when bleeding the system. I'm under the impression that lime has gotten into my system now because of this. Am I assuming correctly? What can I do? Should I call the repairman to fix this problem? Can it be fixed? The hydronic boiler is about 30 years old, closed system.
How long ago he fix it? Perhaps the air will work itself out thru your air scoop if it was just recently. You have adequate heat now?
Why did he use your hot water heater to add water to your boiler? Did he tell you that your pressure reducing valve on your boiler is messed up and thus thats your only option?
Fixed about 3 weeks ago. If anything, the noise is getting slightly louder.
He used the water heater because the water supply to the system is a little slow, so he wanted to speed up the bleeding process. As far as I know the pressure valve is ok.
