what defines a "3-wire" hot water system?
Old 01-06-06, 08:29 AM
X
While I'm becoming a heating expert (chasing an air problem in another thread for over a month; as of today I think we're getting closer to solving it...), here's a question about my zone valves and thermostats.
I have Taco 571 zone valves. They have three wires on the terminal block. Looking at the Taco info sheet on this valve, two wires (1 and 2) go to the thermostat, and two wires (2 and 3) go to the circulator relay. Very straightforward.
But, is this a three-wire system or a two-wire system?
For a battery-powered programmable thermostat, it would appear that many models are specifically "not for three-wire systems."
Thanks for insight.
Old 01-06-06, 04:04 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
2 or 3 wires
Some zone valves need power to both open & close. These would require three wires going to the thermostat. On some thermostats when using heat motor zone valves, such as the Taco 571, you need to add a resistor. If your stat says nothing in the instructions about a resistor & is capable of handling a load of at least 1.5 amps, you should be OK.
Old 01-09-06, 09:33 AM
X
Gotcha. Thanks.
