Going away for a month and turning off water
Old 01-12-06, 12:38 PM
B
Hi,
We're going away on vacation for a month and since it gets pretty cold here I was thinking about turning off the water supply where it enters the house just in case something happens to the furnace and it goes out. If I do this ... do I need to turn off the water heater too ?
I'm afraid that if I leave it on it might damage if the water for somereason goes out. Is there a risk in just turning off the water heater ? Or should I just leave it on ?
(it is a gas heater and gas furnace)
Thanks
Old 01-12-06, 12:53 PM
majakdragon's Avatar
Received 1 Upvote on 1 Post
Basset, Welcome to the DIY Forums.
If you are turning off the water supply, turn off the water heater. Without a water supply, it is possible that the heater would overheat and cause a problem. No risk in turning the gas to the unit off. Good luck and have a fun vacation.
Old 01-12-06, 12:55 PM
B
Thanks for the quick reply Was concerned about coming back and finding a that my basement looks like an icerink
Yes .. a whole month ... whoohoo
Thanks!
Old 01-12-06, 05:13 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Basset
You posted your question in the boilers forum. Is the heat hot air or hot water? If it is hot water, & you do not have a low water cut-off on the boiler, I do not suggest turning off the water.
Old 01-12-06, 05:27 PM
Grady,
Sorry I missed what Forum this was in. Glad you were covering your Forum. Could have been a big mistake made.
