hot water boiler main burner flame high
Old 01-14-06, 09:33 AM
A
hi. have hot a water boiler that its main burner flame is way to high. any suggestions what can cause this? also how to repair? thanks. mike.
Old 01-14-06, 04:34 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Burner flame
How do you know it is too high? The causes could be any of several, some of which would require the use of test equipment most homeowners don't have. I suggest you contact someone familiar with gas burning equipment & the adjustments thereto. Improper adjustment can result in dangerous to devistating situations.
Old 01-14-06, 09:10 PM
A
thanks. the flame is coming out of the sections. what are the causes?
Old 01-15-06, 01:37 PM
Grady's Avatar
Too much flame
The gas pressure might be wrong, the air to the burners may be misadjusted, possible wrong orifices in the burners, boiler might be plugged, vent might be plugged, etc., etc,
Old 01-16-06, 09:22 AM
A
thanks. had a professional out. boiler shot. going with a new boiler.
