weil mclain boiler model pd6,pilot wont stay lit after 60 sec.
Old 01-16-06, 03:26 PM
O
I have a weil mclain boiler (older model pd6). The pilot wont stay lit after the 60 seconds. Have held it for as much as 5 minutes. help! getting cold
Old 01-16-06, 04:06 PM
Grady's Avatar
Received 39 Upvotes on 37 Posts
Pilot problem
The thermocouple is probably bad. The usually cost less than $10 and are avilable at any home center. Make sure the pilot flame hits at least the top 1/3 of the thermocouple.
Old 01-16-06, 04:12 PM
O
grady
The thermocouple you said is available, what would I ask for?
Old 01-16-06, 06:03 PM
Grady's Avatar
Thermocouple
Ask for a thermocouple. They come in various lengths. It would be best to take the old one with you. The length is not critical as long as it is long enough.
Old 11-04-10, 08:28 PM
A
Need Help With a Weil McLain CG (series 11) Boiler Pilot will not stay lit
I happen to have a Weil Mc Lain Boiler Model CG (series 11) Boiler pilot was out and found Thermalcouple was bad Replaced Thermalcouple and pilot will not stay lit. Any help will be greatly appreciated..
Old 11-05-10, 08:48 AM
Albert, you hi-jacked the thread - but since it's so old, there should be no confusion.
How long does the pilot stay lit before it goes out?
Is the tip of the thermocouple in the pilot flame? The size of the pilot flame can be adjusted - the adjustment screw is usually under a larger screw-head on the gas valve.
If that's OK, disconnect the t-couple from the gas valve. Have an assistant hold down the push button, and measure the DC voltage across the t-couple contacts.
