low water cutoff
Old 01-28-06, 09:33 AM
L
low water cutoff
i have a gas furnace,steam radiators. My low water cutoff has started clicking on and off steadily until 1 of 2 things happen. 1) heat comes on 2) i drain water until low water cutoff comes on. I don't see surge in the guage glass. Could it be just the cutoff switch itself?
Old 01-28-06, 04:31 PM
KField's Avatar
If the system is overfilling, you have a problem with the feed valve or float switch depending on the type of water feeder. You can close off the water valve and see if things settle down. A steam system that works correctly needs very little water from week to week.
Ken
Old 01-29-06, 11:54 AM
L
there is no problem with overfilling
Old 01-31-06, 08:16 PM
H
lwc needs to be cleaned you have to take it apart
