Whistling Noise from Gas Furnace
Old 01-29-06, 09:56 AM
T
Lightbulb Whistling Noise from Gas Furnace
My gas furnace creates a whistling noise when it fires up to heat my hot water radiator heating system.
I have had the furnace cleaned, burner changed but I still experience this annoying nose.
Any ideas for me? Thanks.
Old 01-29-06, 11:22 AM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Noise
Can you tell for sure if it is due to combustion or water circulation? If the boiler fires only for heat & not hot water, you could turn off the gas & turn up the thermostat. If the noise still occurs, it is due to circulation rather than combustion. Noises can be real tough in person, on the web nearly impossible.
