Gas valve question on an American Standard boiler
Old 02-07-06, 08:29 AM
E
My gas valve went bad over the weekend.The one we took off was a Honeywell VR8200A 2132.The only one we could find in such short notice and on a weekend was a Honeywell VR8300A 3500.We installed it and everything seems to be working fine.Will this valve be okay to leave on or should I go ahead and find a VR8200A 2132 like we took off??
Thanks in advance,Kevin
Old 02-07-06, 04:22 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Kevin
From what I read in one of my catalogs, the 8300 would seem to be a comparable valve with a higher capacity. Anytime a gas valve is changed, the gas pressure should be checked so you know you are not putting more or less gas into the appliance than it is designed for.
Old 02-08-06, 08:36 AM
E
Thanks for the reply Grady.I know the 8300 had a maximum capacity of 190k btu and the 8200 was 130k btu I think.When I questioned the guy I bought the valve from about this he said there shouldn't be a problem because the burners were regulated by the orifice size I believe he called them.I was just wanting to get a second opinion since I was worried about the difference in the max btu ratings.Do you think I should be worried about the difference or do you think the guy was telling me the truth??
Thanks again,Kevin
Old 02-08-06, 05:14 PM
Grady's Avatar
Gas Valve
From what I see in my catalog, you should be fine. The 8300 has a higher capacity than did the original 8200. I saw nothing about minimums.
Old 02-09-06, 08:48 AM
E
That makes me feel better Grady.Now I just found out another possible mistake we made.We used white teflon tape to help seal the connections.Was that a big mistake and should we redo everything??
Thanks Kevin
Old 02-09-06, 05:08 PM
Grady's Avatar
Teflon Tape
Most definately a major boo-boo. Take the valve off blow it out well but gently with canned air & reinstall using pipe dope sparingly. Be sure to leak check when done.
FYI: The teflon tape can get under the seat of the valve & cause it not to close completely.
Old 02-10-06, 11:07 PM
E
I will definately try and get that done this weekend.Can I use the yellow teflon tape I heard about or should we use the pipe dope?? Didn't know if all teflon tape was a no no to use when working with gas or just the white tape.
Thanks again for all your help.
Old 02-11-06, 04:00 PM
Grady's Avatar
Teflon tape
Do not use any kind of teflon tape on a gas valve, pipe dope only & then sparingly.
Old 02-16-06, 10:48 PM
E
Grady:
Thanks for all your help.It is greatly appreciated.
Kevin
Old 02-17-06, 02:30 PM
Grady's Avatar
Kevin
You are most welcome. Glad I could help.
Should any other problems with the boiler, or just about anything else around the house, crop up, there are experts in almost any field here on DIY.com who will be as glad to help as I.
