Water system- temperature very high
Old 02-19-06, 03:50 PM
Adrian Dams
I have a water heat system and a boiler. The rads are all bled and the pressure is about 100KPA. When the boiler switches on, though, the temperature of the water being circulated gets pretty high - over 100 deg c.
What must I do to stop it going this high?
Adrian
Old 02-20-06, 06:10 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Water temperature
Is this 100+ C actually measured with an independent thermometer or are you trusting the gauge on the boiler? Boiler gauges are notorious for being inaccurate. I suggest buying an electronic thermometer with a remote probe. Put the probe against the main supply pipe coming off of the boiler & insuate it well with foam pipe insulation, fiberglass, or even a towel wrapped several times around the pipe & probe. These thermometers are fairly inexpensive and are available at electronics stores & some home centers.
