Fighting A loosing Battle
I really could use some help here. I have a old (about 1950 to 1960) gas fired American Standard boiler witch I think is starting to come to its end. The circ pump is leaking through a oil hole I know I need to fix or replace that, but my problem is all of a sudden(has been fine till a week ago) it is over pressuring and blowing the relief valve. I've tried to bleed the base boards and drained the expansion tank but no luck. Any knid of help would be great! Thanks!
Received 41 Upvotes
Over Pressure
When you drained the expansion tank, if you did not drain it completely, you need to. Other causes of over pressurizing are a leaking domestic coil (if your boiler has one) & a pressure reducing valve leaking thru.
Received 41 Upvotes
Losing battle
Before any more damage is done, you really should call a local servicer. It could be something simple. Watch, ask questions, & learn. Most service guys/gals don't mind at all. In fact we would much rather teach you than have you really mess something up which makes our job tougher & costs you money.
