Boiler Control Module Replacement?
My boiler is running much to hot to be efficient, I wanted to drop the set temperature from 180 deg F to 100 deg F. The range of my L8148E controller bottoms out at 180 deg F, so I went to find a new controller.
I was pointed toward and purchased an Aquastat Relay (AQ475A) from Honeywell to replace Aquastat Relay (L8148E). While trying to install the new part I have found there seems to be a bit of incompatability between the two units.
The "Boiler Aquastat" node from the AQ475 unit requires 120Vac where the "Burner" node from the L8114E requires 24Vac. What will I need to achieve compatibility, or will I need to find another unit?
