Radiant heat mixing valve problem
Old 04-12-06, 08:51 AM
larjo
I have a Watts thermostatic mixing valve in my radiant heat system that seems to be partly blocked. I have emailed Watts about how to clean it but did not receive a reply. Back flushing through the valve did not seem to help. If I remove the valve, do I just mechanically clean it with a brush or should it be soaked in some sort of cleaner? Any suggestions would be appreciated.
Old 04-12-06, 03:36 PM
U
Did you try a google search on this? I found 2 sites, one with a vavle troubleshooting guide. search under "cleaning watts mixing valve".
Old 04-13-06, 12:09 AM
bolide's Avatar
Received 1 Upvote on 1 Post
Post
Radiant heating systems are not covered in the Plumbing & Piping forum.
