Moving steam Pipes
Old 07-05-06, 03:25 PM
T
Moving steam Pipes
I have a 40 yr old home with steam heat with cast iron recessed radiators.
In the basement the main heat loop is comprised of 2" pipe with various tees going to each radiator approx 1 1/2. the connection into the boiler Well Mcclain is with copper. I have to move some of the 2" pipes in the loop. Do I need to use the same type of pipe or can I use copper. Is the old pipe galvanized.
Tearflop
Old 07-05-06, 06:11 PM
R
Tearflop
If you have never done heating work on steam then I suggest that you get a pro in. Staem pipes have to be pitched back to the boiler and other conciderations have to be made during that time.
Old 07-06-06, 05:14 PM
Grady's Avatar
Received 40 Upvotes on 38 Posts
Re-piping
I agree with Rob. Steam piping is far more critical than that of hot water. In general, black steel pipe is the prefered piping material.
Old 07-06-06, 07:34 PM
T
thanks for the input...I just called in a pro...He is going to use black pipe for the job....thanks
Tearflop
Old 07-07-06, 02:56 PM
Grady's Avatar
Tearflop
Smart move.
