Wiring boiler
Wiring boiler
My Oil burner has two separate circuits in my panel. Only one 110v line is connected to the burner. I am assuming the other one is for the thermostat. Is this correct and does the thermostat require its own circuit or can I wire it into another circuit or the burner circuit. This system was originally installed in 1952.
I would like to rewire the burner and Thermostat the correct way. I will replaceing the thermostat.
Thermostat uses low voltage wiring. 110V AC goes to the boiler using 14-2 wire, then is converted to lower voltage. They are totally different wires. Never mix them up, or you are in danger. Low voltage wire is much thinner.
Received 38 Upvotes
Also, while most thermostats are low-voltage, line voltage thermostats do indeed exist and a 1952 installation could very well have a line voltage thermostat.
John, please copy all the information you can find on your boiler, burner, thermostat and any parts that have wires connected and post them. Pictures are always helpful, more are better than few.
I traced the other circuit it is capped off in a box I uncovered today. The burner that's in there now was installed about 5 years ago. It's a Becket burner. The control box is a Honeywell (R8184G 4066). There is no separate transformer. I checked the thermostat terminals on the Honeywell box with a volt meter 21.1 Volts. Is this correct two low voltage wires from the thermostat to the burner. I am going to correct the wiring and remove the extra circuit. I want to install a new thermostat and replace this wiring also. Is this the best way to go or is there a better thermostat setup? I am capable of doing the wiring but I want to make sure it is correct.
