Weil-McLain WTGO boiler burning chamber water leak
Old 08-06-06, 11:12 PM
G
I have a about 10-years old WM WTGO-4 oil boiler has a lot water leak into the burning chamber when I out of town and shut it down for about a week. The leak is so serious that the burning chamber is half full of water when I opened.
I checked inside the boiler, it seem to me the water is coming from the section of the cast iron. I don't know much about the boiler, and didn't get my answer when search this forum.
Is this boiler sealed with O-ring or nipple?
How hard to get it repaired / re-sealed with DIY?
If have to hire a contractor, what's the estimated cost?
Any help and advice are appreciated.
-- garfield
Old 08-07-06, 05:55 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Weil-McLain
This boiler's sections are sealed together with "elastomeric seals", which in English means rubber. If you are lucky, it is just a seal which has gone bad & may be covered under warranty. You will have to pay the labor which is far & away the lion's share of the repair bill. Never having done this type of repair, I can't give you an idea as to cost.
Old 08-08-06, 07:35 PM
G
Thanks
Thanks for the info, will find a contractor do it.
