Diagrams for boiler hookup???
Old 09-01-06, 12:29 PM
K
Well here goes...
#1 Is there a website that shows basic system designs using multiple zones.
#2 I am hooking up a new oil boiler at my cottage.
3 zones controlled by taco 007 pumps and a 503 zone system control. Weil Mclain Oil Boiler 88,000 input direct vent setup new and unfired.
Question on my hookup, I am feeding 2 zones of radiant tubing in the first floor in the slab that would require approx. 120 degree water. The 2nd floor has a air handler that would perform better with higher temperature water. I will run all on same temp if neccessary. How can I mix this using primary secondary system. My worry is that if I keep the temp this low I will have early problems with the boiler as I am told that running longer cycles is much better for them.
I have access to any parts or pieces you can come up with and am very mechanically inclined.
Thanks in advance any guidance.
Kevin
Old 09-01-06, 02:05 PM
X
resources
search the Taco file library for the "radiant made easy" guide. Comes in a bunch of separate chapters. Good reading.
also www.tekmarcontrols.com and search through the technical essays for mixing options from 3-way to 4-way to variable speed injection. also check out their controls. you could ditch the taco SR and go with a mixing control that does everything. their application and description guides are excellent.
there's a book called "primary-secondary pumping made easy", I think by Dan Holohan. Google it.
not too hard to get this stuff right, but very painful to get wrong.
good luck.
Old 09-01-06, 02:10 PM
K
Talking
EXCELLENT!! going to check those sources now.
Thanks
