Expansion tanks
Old 09-21-06, 07:09 PM
T
Expansion tanks
I took out our old Extrol Model 30 expansion tank because it developed a leak. Lowe's carries a thermal expansion tank that seems to be made for water heaters. My question is whether I can use the Lowe's tank on my heating system. To me, the tank is built the same and works the same way (has a maximum psi of 150, whereas my Extrol max was 100 psi). Is this okay? What else should I be concerned about?
Thanks for any help you can give.
Terry
Old 09-21-06, 07:23 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Expansion tank
Do not use this type of tank. The rubber in the bladder will not withstand the heat of a boiler. Any plumbing supply house should have the type tank you need.
Old 09-21-06, 07:49 PM
T
Is the boiler that much hotter than the water in the hot water heater?
Old 09-21-06, 07:58 PM
Grady's Avatar
Temperature
Water heaters are usually limited to 140-160. A boiler can easily reach 200+.
Old 09-21-06, 08:56 PM
T
Thanks for the advice. I'll check with a plumbing supply store tomorrow.
