Secondary aquastat
Old 09-27-06, 06:02 PM
B
ben
ben is offline
Secondary aquastat
Is Secondary aquastat a must on a HW boiler? or is it something good to have for the saft purpose? how about based on code?
Thanks for the help
Old 09-28-06, 03:39 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Secondary Aquastat
By secondary aquastat I presume you mean a secondary high limit. It is required on all commercial buildings but codes vary by location on residential applications. You need to check with your local code officials. As a rule, the more safety devices the better.
Old 09-29-06, 06:14 AM
B
ben
ben is offline
Thanks Grady.. yes I was talking about the secondary high limit. Someone told me that is is a must and that is why I asked. I think I will add one since it is a safety device.
How about a low water cut-off. I do not have any heat distributors installed below HW boiler. Should I install one anyway just to be on the safeside?
Old 09-29-06, 02:15 PM
Grady's Avatar
Low water cut-off
A low water cut-off is always a good idea. It can save a boiler from dry firing or excessive fresh water feeding. When a LWCO is installed, you should shut off the feed water. If the LWCO trips, you know you have a leak.
