one zone not working
When I turn up the thermostat for zone one and then go down to the boiler in the basement. There are 3 zones each zone has a little box with a transformer in it. On the zone that is not working the box with the transformer will just humm. Help I cannot seem to find anyone that has the time to work on it.
Received 39 Upvotes
Zone problem
Those boxes are likely switching relays. There should be 120 volts coming in (usually terminal #1). You should have 24 volts between the terminals to which the thermostat wires connect. When the thermostat calls for heat, the relay should pull in & send 120 volts to the circulator via termal #3 (usually).
