Aquastat L8148A,E ?
Old 10-06-06, 10:22 AM
Z
Aquastat L8148A,E ?
I need L8148A stat for my oil boiler. The guy I'm getting it from says in says L8148A,E on the box. Does Honeywell actually makes A and E models combined in one? If not, would gas model E work for my oil boiler? I would say not, but just checking.
As far as I know here are their differences:
L8148A: Burner voltage-line, mounting case-horizontal
L8148E : Burner voltage-low, mounting-vertical and it has plug for vent damper.
Also, it shouldn't be a problem to have 8148 to lay on its back
http://www.watsonsheating.com/images/FamilyPic1_569.jpg
Thx
PS. why is my [img] code is off? not enough posts?
***Moderator's note: See reason for editing re: IMG code***
Last edited by DIYaddict; 10-06-06 at 10:35 AM. Reason: Removed IMG tags for easier copying and pasting. Sorry it's not you. The IMG code is off right now.
Old 10-06-06, 03:24 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Aquastat
You need the L8148A. In order to use the E, you would need a relay. The burner is 120 not 24 volts.
Old 10-06-06, 07:19 PM
X
Nice boiler. Your air scoop leaks. Fix it while you're doing the stat.
Old 10-06-06, 08:23 PM
Grady's Avatar
Leak
Darn, that Xiphias has good eyes.
Glad to see someone besides myself installs a ball valve between the system & the expansion tank.
Yep, fix the leak. No need in having such a good looking & good quality boiler like that & a streak of rust.
Old 10-07-06, 07:18 AM
Z
Well, that pic is not my boiler. I'm just going for exactly the same Buderus Logano G115 with Buderus S-120 indirect and trying to get all stuff together before I proceed with install. Actually this pic you see is a boiler installed by homeowner himself as well and he did pretty good job.
The only thing I would add there are:
He needs:
1)firematic at the burner, 2) LWCO
and you are right, his scoop is leaking (used to leak) there.
BTW, do you think it's a problem to have 8148 lay on its back like that? I don't think it would but just checking.
http://www.watsonsheating.com/images/FamilyPic1_574.jpg
Old 10-07-06, 09:31 AM
Acquastat
That's an awfully odd location for an aquastat.
Pete
Old 10-07-06, 01:35 PM
Grady's Avatar
Aquastat Mounting
There is nothing wrong in it's location. My Crown CT-3 has the aquastat (L8148A) factory installed in exactly the same way.
Old 10-10-06, 07:56 PM
L8148a
I know it is prob too late but The L8148A is pretty good unit,test the line voltage then transformer voltage then relay...Sometimes before you run to the shop to buy a new replacement shut off boiler power, test that it is off at the L8148A line in...then with no power un-connect all the wire nuts and Thermo TT wires do this step by step unless your not old like I am and can put each wire nut on to each wire as they belong. and last reconect the Thermostat wires and turn the power on....Sometimes just one wire in a wire nut may not be makeing contact yet to the eye it looks all snug and wire-nutted... And many times a perfectly good control tested bad only to be replaced when all that was wrong was a hidden wire in a wire nut that was not makeing good contact. A good voltage tester is only as good as the conections it is testing for.....
Silver_Eagle
