very very low hot water pressure but normal cold water
Old 10-13-06, 11:41 AM
L
Hi
I just shut down my water the other day to attach a tube from the garage into my new fridge for water and ice. When I finish hooking everything up and turn the water back on, the hot water isn't working right. The cold water is normal like it was before the project began, but I'm hardly getting any hot water. The hot water pressure is very very weak.
I can't figure out what could be causing this?
Thanks in advance for the help.
***Moderator's note: Duplicate thread created in Plumbing & Piping Forum has been deleted***
Last edited by DIYaddict; 10-13-06 at 12:00 PM. Reason: See moderator's note in post
Old 10-13-06, 11:47 AM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
Info info helps . What all do you have there ??? what are where did you shut off the water?
What pressure do you get if you open the drain on the water tank???
ED
