Replacing B&G Circulating Pump
Old 11-01-06, 06:28 PM
I have a pump that 'sqeals like a pig' at times and it has off and on for the last year or so but I forgot about it until now the cold weather is back. This is also an original pump so likley 50 years old.
So I'm oiling it but was wondering if I had to replace it how does one go about that?
I mean after I remove power can I disconnect it without having to drain the water out of the heating system? Like, the motor must just have a shaft that connects to the impleller and there is a seal in the housing that keeps the water on the other side right?
http://www.bellgossett.com/homeowners/CM--PumpCutAway.htm
Actually now that I look at it 'on the web' maybe it is the whole assembly I would have to replace which would mean shutting off the water and draining the system etc. Correct?
Maybe not, show's how much I know about this stuff...
http://www.bellgossett.com/homeown/manuals/1.4.htm
Old 11-01-06, 08:27 PM
Grady's Avatar
Received 40 Upvotes on 38 Posts
Replacing Circulator
If you are replacing the whole circulator, you will want to use one of the newer wet rotor types. You can buy a whole circulator for less than the cost of a bearing assembly for the B&G 100. Let the boiler cool, close any valves you can find, drop the pressure to zero, & remove the four flange bolts. Before putting the new circ in place, be sure to clean off any old gasket stuck to the flanges. I can usually change one in less than 15 minutes. It might take you 30.
Old 11-02-06, 09:23 AM
Andrew's Avatar
Received 14 Upvotes on 10 Posts
I agree with Grady; lose the B&G & get a wet rotor style pump. I replaced my B&G series 100 pump with a Taco 007, and it is quieter & maintenance free.
Gooid Luck!
Old 11-02-06, 03:59 PM
Thumbs up I'll check it out
Thanks guys I'll check out these new fangled 'wet rotor' types.
It even sounds impressive, you know '007'.
