Slant fin base board noise
Old 11-04-06, 05:45 PM
L
Hello, Me again.
1) I have 1 (forced H W) zone on my boiler,(2nd flr) I have bled it several times, but it is still noisey, (sounds like drums).After it's good for a few days then slowley returns, not your typical expansion sounds. No bleaders on the base, must be done from the basement.
2) do I need to keep my make up water on, or can it be shut, This is a closed loop right?
3) I assume when I change my water filter (well) I should keep it shut untill I blead the house system.
Old 11-05-06, 08:42 AM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Noise
Are you maintaining a constant pressure on the system?
