lost power, can't find reset button
Old 11-07-06, 11:26 PM
K
Smile lost power, can't find reset button
recently lost power hot water heater did not re-heat. electric approx. l yr old. found termostat, but can't find re-set button kaymarie
Old 11-08-06, 07:58 AM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Electric Water Heater
It should not need resetting but just in case, the reset button should be at the upper thermostat.
Old 11-10-06, 02:12 PM
K
re-set hot water heater
you said the sre-set would be by the upper thermostat. the one i found was near the bottom of the heater, are there 2 thermostats?
Old 11-10-06, 02:18 PM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
Im with Grady push the reset bottom. But yes on a electric hot water there are 2 tstat and the red reset button is in the top tstat. So I dont know what you have there for sure
Old 11-10-06, 06:24 PM
Grady's Avatar
Single or dual element
It is possible you have a single element water heater. If that is the case there would be only one thermostat & the reset button should be with it. Look above where you found the one for another access panel.
Old 12-05-06, 08:03 AM
K
to grady
you were right re-set behind upper panel, i pushed it but it did not stay in, should it have? I'll wait to see if water heats. thank you kay
Old 12-05-06, 02:50 PM
NJT's Avatar
NJT
NJT is offline
Received 8 Upvotes on 6 Posts
You did check the circuit breaker panel to make sure no breakers are tripped ?
Old 12-05-06, 06:26 PM
Grady's Avatar
Reset Button
If the button did not stay in, you need a new thermostat & limit control.
