Cold Start vs Hot Start ??
Old 11-11-06, 05:09 AM
Z
Received 2 Upvotes on 1 Post
I have a natural gas 3 zone hydronic baseboard heat system. It is not used for hot water - I have a separate hot water tank. Question is that I noticed even on warm days that the boiler always fires to maintain a temp about 180 deg. even though there is no call for heat. Is it wise to change this so that the furnace fires only if there is a call for heat?
Thanks
Gene
Old 11-12-06, 12:35 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Converting to cold start
If the boiler has stayed hot for many years, you may create leaks by converting to cold start. It is a gamble. The upside is usually if reverted to staying hot, the leaks will stop. If the boiler is in a basement & subject to dampness, especially during the summer, you could get a lot of rust in the flueways.
