boiler temp is low, won't start, primary controller light flashing
Old 11-11-06, 01:22 PM
7
just got home from work, noticed it cold in here, went to check boiler, noticed light flashing on primary controller..hit the reset
nothing, feels like the circulators are on, temp in boiler is at or below 70. but boiler makes no attempts to fire...help..
Old 11-12-06, 01:46 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Cold boiler
Sorry for the slow reply.
If you don't have it fixed, what is the brand & model number on the primary control? If it is a Honeywell or Beckett 7184, push & hold the reset for 45-60 seconds then release. If the burner does not fire, DO NOT try it again. There are many things which can cause an oil burner not to fire. If it is anything except a clogged nozzle, each time you reset it, you are pumping fuel into the chamber.
Old 11-12-06, 05:48 PM
7
it is a beckett 7184, it has the beckett cleancut fuel unit on it. it will run gfor about 20 secs and then the light starts flashing again, about once every 1/2 sec. i do not have 24 volts on it or from my aquastat.
Old 11-12-06, 05:54 PM
B
burner lock-out
It's not firing or it's not sensing that it has fired. STOP reseting it before you flood the chamber with oil. Call a qualified oilheat service provider.
