need a gauge
Old 11-29-06, 06:05 AM
X
need a gauge
I have a plug on the elbow of my return manifold that is crying for a nice, accurate temp and pressure gauge. Lollipop style.
Brand/model suggestions?
Thanks.
Old 11-29-06, 06:15 AM
gauge
I hear the Chinese versions are to be avoided.
Pete
Old 11-29-06, 03:32 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Temperature & pressure gauge
I suggest separate devices. I've yet to see a good combo gauge. Most of the OEM stuff is an estimate at best.
Old 11-29-06, 03:53 PM
X
OK. Temp then. Suggested brand?
Old 11-29-06, 05:27 PM
Grady's Avatar
Thermometer
I found a nice one in my R E Michels catalog. They list the manufacturer as Neiss. It is a model DVU35 & uses well #E35-75BS.
Old 11-29-06, 06:18 PM
X
Weiss. Fancy. Very cool. Thanks.
Old 11-30-06, 01:57 PM
Grady's Avatar
Weiss
No wonder I couldn't find it elsewhere on the web. Name wrong in the stinking catalog & dummy didn't even think of Weiss.
Old 11-30-06, 07:10 PM
X
here's the ticket!
http://www.weissinstruments.com/oemtriometer.htm
The CTP40L looks like just the thing.
Old 11-30-06, 07:58 PM
NJT's Avatar
NJT
NJT is offline
Received 8 Upvotes on 6 Posts
Here's a few more to look at:
http://www.houseneeds.com/shop/HeatingProducts/HydronicHeating/Gauges/temperaturegaugeindexpage.asp
Old 12-01-06, 04:22 PM
Grady's Avatar
Tri-indicator
If all you want is a run of the mill gauge, that should fill the bill. I thought you were looking for accuracy.
Old 12-01-06, 06:03 PM
NJT's Avatar
NJT
NJT is offline
Grady, you mean the houseneeds cheapos, not the Weiss , right ?
Old 12-01-06, 06:59 PM
X
I believe Grady is referring to the Weiss. Upon further reading, at +/- 3% over the 60-260F range, it's only accurate to +/- 6F. I already know my other sensors are within 2F, so looks like I need a better gauge as much of what I want to measure is <8F. Will keep searching. I'd like to do pressure, too.
Old 12-02-06, 10:55 AM
Grady's Avatar
Temp & pressure
I believe the original Weiss I suggested was +/- 1%. Pressure could be done by using a tee or drilling & tapping the pipe.
