Expansion Tank Position ??
Old 12-06-06, 03:30 PM
JackOfAll Hills's Avatar
Cool Expansion Tank Position ??
Does it matter which direction a hot water heat expansion tank is mounted, Horizontal or upright with the water inlet @ the top? Any advise appreciated
Old 12-06-06, 03:44 PM
Ed Imeduc's Avatar
Received 1 Upvote on 1 Post
Wink
Id go upright With the water inlet on the bottom.Sc hrader on the top
Old 12-06-06, 04:02 PM
Grady's Avatar
Received 41 Upvotes on 39 Posts
Tank position
It really makes no real difference which way the tank is mounted but I prefer the schrader to be down. One of those chocolate & vanilla things.
Old 12-06-06, 04:17 PM
NJT's Avatar
NJT
NJT is offline
Received 8 Upvotes on 6 Posts
On potable water systems, I usually go with the Schrader on top. This helps keep "crud" from collecting in the tank. Virtually every well water expansion tank you see will have the schrader on top.
Heating systems, I'm with Grady.
